To be honest with you man I haven't got enough experience to say but this is what I did.
I did the heat treating in my coal forge. Because of the long soak time it needs I used a crap load if flux to prevent scale. Did my normalizing cycles and then hardened it in canola oil. I tempered at 450 for three, two hour cycles. It warped a bit after everything was done so I tried using the dowel/vice trick and it would just spring. It's still got a slight warp but now that the handle is on you can't see it. I then took the oxy acetylene torch and drew the temper to a blue down the spine, just to prevent it from cracking.
Time will tell if it will work well. I'm sure it will, before my friend gets it I want to chop up some 2x4's.
Thanks for all the nice complements everybody. It really means a lot to me!
