Chopper needed
Okay I have been pointed at a 30+ acreage filled with Elm, Oak and Pine trees and told to clear out the thousands of Raspberry bushes growing on the rocky ground between the trees. Adding to the fun of the thorns (some of inch size) is the discovery that everything is hung with Kudzu and other vines. Cut the bottom of a bush and everything just hangs there dangling in the breeze by the Kudzu vine. Because of the rocks and tight spaces bush hogging from a tractor isn't an option and hand pushed machines (i.e., a DR) are being used along with the chain saws and other human guided implements.
I have a machete, but quickly found it was too long for good swings in the spaces I am working. My 5" knives don't quite have enough swing (or mass/inertia) in their chop for a single stroke on the vines (some up to 1.5" in thickness). I need a decent chopping knife. Don't need a lot of weight, but I do need it to bite when swung in tight spaces. Suggestions?
The Browning Barker Competition knife sounds perfect for what you are doing. Its light in the hand and fast but bites deep. Check them out they are well worth the money IMHO.
Gerber brush knife -
I live on property similar to what you describe.. lots of vines, brambles, small trees and thick brush.
A brush hook is perfect for this kind of work because the hook allows you to cut lighter weight stuff without pushing it off the blade. It is also good for gathering up vines and such so you can grab and hold them while you cut.
The blade is lightweight and thin, so it swings fast and cuts well. The handle is long, so you can use a variety of grips, and you can choke up on it in tighter spaces.
Andy
You just flashed my memory of the knife I probably need. A US Army LC-14. Woodsman's Pal to those born after WWII. Forgot all about those till you showed me the Gerber. Thanks.
Brush hooks work great--brush axes especially. You can really clear out a large swath quickly with one of those. Try to find one with a nicely hooked/rounded tip, as it will bounce off of stones rather than your edge taking the damage. I've got an old one I got at an antique tool store and it's cleared more than its fair share of brambles and raspberry bushes in its day. Not sure where you'd get a new one, but you might want to give 'em a look!
