I found numerous planks of wood while clearing out my grandparent's garage. I decided to conduct a series of tests to compare the chopping abilities of my Busse blades. I plan on testing the Battle Mistress-E, the Steel Heart-E, the Paul's Hatchet, and possibly my Satin Jack variant.
My first test was on a board of light-medium density, unidentified pine. The board was 3/4"x4"x39". It had about six growth rings per linear inch, and weighed about .43 ounce per cubic inch. The knives were scrape-shaving-sharp, to reflect the typical outdoors-use conditions of lackadaisical maintainence.
The procedure was simple: Chop once with my BM-E, move over a foot and chop once with my SH-E, move over a foot and chop once with my PH. Then repeat. Photograph after every cycle of ten chops per blade. Count the total total number of chops per blade required to chop through the board.
As you may have already guessed from my description of the plank used for the first test, things didn't go as planned. After a few chops, the test ended suddenly when my Battle Mistress cracked the plank into pieces. Ah, well... I have more boards--heavier ones, and will be conducting more tests during free moments over the next week or so.
I did learn a few things from the test, already, though.
1) Chops made by the BM and by the SH veer slightly to the left as they penetrate wood, while chops with the PH go perfectly straight. Presumably, this is because the BM and SH have assymetrical edges, while the PH has a symmetrical edge. I will have to experiment with what happens when I chop with my other hand.
2) A result which I wasn't even looking for quickly became apparent. Because I was moving over a foot or two after each chop, I did not garner the advantage of mechanical repetition, which can make consecutive chops very accurate. Instead, I had to aim completely anew with each chop. This made it clear to me for the first time that aiming ease was proportionate to blade length. (I'm sure that there's a point at which this reaches an optimum, after which it reverses, again. However, I don't know how long my optimal length for aiming accuracy is.) The Battle Mistress was easiest to aim precisely where I wanted to chop; the Steel Heart was next easiest; and the Paul's Hatchet was considerably harder. Besides the greater chopping power of the BM over the SH over the PH, the increased aiming accurancy of my strokes greatly increased the Battle Mistress's effectiveness per chop over the Steel Heart's over the Paul's Hatchet's. (I should note that I've chopped through fallen trees with my Paul's Hatchet, and it is still a very capable chopper in it's own right.)
3) The Battle Mistress seemed to bind most in this board. It can really cut deeply through pine of this thickness and density. Nevertheless, the binding was still negligible. The Steel Heart and Paul's Hatchet did not bind at all.
More tests are forthcoming. Meanwhile, I am open to suggestions for conducting my tests as best possible. (Cliff?)
--Mike
--Mike
