- Feb 1, 2001
I have had an old drop in bed liner in the back yard ever sense I had a Rinoliner sprayed in my Chevy bed. Today I got tired of looking at it so I tested out 3 khukuris on it. The bed liner is 3/16 thick and is made of a hard but plyable plastic. It was also covered in mud and dirt. I used one of my older Ak's made by "KGR", a newer steel mounted AK with finger grooves and my steel mounted Ghopte. All khuks are 15 inches long and razor sharp. I started to cut up the liner with the "KGR" AK and I started on a wheel well which was hard to penetrate using the belly and the knife wanted to bounce off. I took severall chops to cut through but once I was through I could make cuts about 3-5 inches long per chop. The liner was lying on the ground when I started to chop. When I stood the liner on end I could swing down and the knife cut much better, I could now cut close to 10-12 inches with one swing. After I was done cutting the 1st 1/3rd of the liner up(20 minutes of cutting) I checked the edge of the knife and it was still very sharp, it would still shave a little and the edge had no dammage at all.
Next I used the steel mounted AK with finger grooves and it was comfortable to use but I didn't use it long enough to tell a differance between it and a normal handle. It's performance was very close to the "KGR" AK and it also held it's edge.
The Ghopte actually was the best performer by far. I'm not sure why but using the same force it could cut about 3-4 inches deeper than both AK's and it ate right through the other wheel well with out bouncing off. The 3 knives were the same 1/2 thick but the Ghopte was almost an inch wider so the bulk of the blade is thinner? That is my guess! They all performed equaly well stabing the liner and the Ghopte was again better at slash cuts. I have a few large sections left so I will test a few other khukuris next and tell you how they do. Right now the Ghopte is the knig at cutting hard plastic but we have alot of other things to test them out on as well!
Do you think that plastic is harder on a knife than hard wood? Bed liners are made to be tough so I thought this would be a good way to test the durabilty of the khukuris edge which by the way all 3 were undamaged and could still shave. What do you think?
