Christmas Activities
Here is what we did for Christmas today..me, my two brothers in law.
The good? Lots of fun, we started a mini fire practicing with firesteel (took us a while, everything was soaking and honestly it went out pretty quick because we didn't stack dry fuel).
The bad? Chipped infi on a knife I just got. :(
Check out our pics.
http://www.flickr.com/photos/57455190@N07/?saved=1
Curious. Exactly how did that happen? Have you tried to steel it out? or resharpen it?
I'm not sure. All it hit was some wood, and a little bit of rubber (old tire, but we stabbed it mostly not chopped it).
Haven't tried to correct it yet, it's actually fairly deep chipping. Makes me sad, first time I've put it to work.
Precisely what I was thinking, but I didn't think that'd do it considering I didn't really chop so much as just stab the sidewall..also kinda figured infi could handle it.
What's my best bet for smoothing that out? Never dealt with chips that extreme yet.
With rolling like that, you will have to try steeling it out and then move on to sand paper. Appears to be a convex grind, so I use either a slack belt sander, or sandpaper mousepad technique.
Also, looks like that convex grind was applied by some one aftermarket. Might have taken it a bit thin for abuse.
Not 100% but pretty sure ban did it. Not sure what "steeling out" is honestly I'm pretty new to convex. Know the sandpaper mousepad technique though.
'steeling' refers to using a smooth version of the classic butchers steel. Any smooth, hard, rounded surface will do, such as the shaft of a screwdriver or some other tool. Put the knife in a vise and stroke the steel firmly across the edge. The idea is to roll the metal back in line with the edge. Sometimes the steel at the edge is not really chipped, but just bent out of line. So you can move it back. If that does not work, then just sharpen normally with your paper/mousepad and eventually the damage will disappear.
I had something similar happen to an FBM; chopped into a log only to find a piece of a saw blade left in the wood. No regrets, they are users, right?
You got it! Still makes me frown though.
Now to find someone who will sell me their user cgfbm so I can chop compare :)
Yup, steeling is just using a smooth piece of "steel" to push the edge back into alignment.
The edge on infi will typically deform a bit rather than chipping or tearing out.
You can get pieces to actually get torn out, but usually it is an actually tearing not chipping. (this is only really apparent if you look under magnification).
Chips normally look like a flake of the metal popped out, and will usually leave a different color metal look in the spot where the chip came from.
When I damage my edge, I use the steel first. I use a large round polished or chromed screw driver shaft, since I don't have a nice butchers steel.
Apply repeated strokes moving from spine to edge (some have suggested putting the knife in a vise and moving the "steel" along the edge. For the love of Pete, though, be careful, because you have 10 inches of Sharp Infi wanting to take your fingers off.
I have had success with just freehanding with out clamping it in my vice.
Just spend some time with the steel first, before attempting to sharpen it back up with the sandpaper, mousepad, strop.
It will push a surprising amount of steel back into place and you will have to remove a lot less than you thing, or if you just go straight to sharpening.
The three times I have had to do this with my infi (edge spine contact on another knife, chopped a small pebble in half on accident, and pried some tacks loose from wood with the edge of one of my SS) all three would have taken longer and more sharpening if I had not used the steel method first.
Also, don't use the modern "steels" they sell with normal knife sets, the kind with the grooves running lengthwise. They actually remove metal, which you don't want at this stage.
If you can find a steel that is actually a steel (ie no grooves, or abrasives embedded in the steel......ie diamond or such).
If you can't just find a nice smooth round screwdriver. You could actually just grind the top off of one and make it your dedicated steel if you want.
Use some care as if you are using a screwdriver, you can also make some deep scratches in the blade with the screw driver head if you are not careful.
