Chtorrknives
Hallo, I am new here and I would like share some of my older and newer knives. Thank you.
Blade length: 135mm
Total length: 295mm
Blade width: 27mm
Blade thickness: 4mm
Item weight:
Blade: RWL 34
heartlessness :60Hrc
Handle: bone,titan
Welcome to BladeForums,Chtorr.:thumbup:
Share away.If you need help let us know. :)
Doug
Blade length: 130mm
Total length: 250mm
Blade width: 30mm
Item weight:
Blade: N690
Handle: Bubingo wood
Sheath: cow hide
Blade length: 130mm
Blade width: 30mm
Item weight:
Blade:Damasteel
Handle: buffalo horn
Blade length: 160mm
Total length: 280mm
Blade width: 35mm
Item weight:
Blade: RWL 34
Handle: Palisander wood
Sheath: cow hide
Blade length: 115mm
Total length: 215mm
Blade width: 28mm
Item weight:
Blade: Damascus
heartlessness :Hrc
Sheath: Palisander wood
Blade length: 180mm
Total length: 315mm
Blade width: 40mm
Item weight:
Blade: RWL 34
Handle: Damasteel,eben wood
Thank you. I am a hobby maker and I personally like RWL34 as a knife steel (it's really perfect material) and Damascus steel for some kind of knives.
very aesome blades...
is that some kind of locking mechanism on that friction folder?
Very nice work Sir, welcome to BF hope you stay awhile :)
I'm also with Siguy and curious about the friction folder
new model
album_pic.php
The other side of the blade (when closed) has a flat end that can be used as
> a tamper - for tamping down the tobacco when the bowl is being packed and
> for crushing the ash together to aid relighting. 1-2
> The pick (narrow pin on the side of the knife) can be used to loosen tobacco
> or to clean the airhole leading to the tobacco chamber when it's full of
> ashes.
I really like the work on the balis. Really. That black handled one makes me want to start working on trades!
But the pipe smoker's friction folder.... dude. that's just a complete piece of work. VERY well thought out, and perfectly executed. I love it. What multitools should be ;)
you should hang out over on the makers section, too.
thank you behind approbation and here's new bit
Blade length: 100mm
Total length: 130mm
Blade width: 22mm
Blade thickness: 3,5mm
Item weight:
Blade: RWL 34
Handle: inox,bone
