- Jan 16, 2006
I was doing some research on iron and ran across the term Curie Point. This is the temp that iron is no longer magnetic and was discovered by Pierre Curie (Madam Curies husband). My question is why do knifemakers refer to it as critical temp when the scientific term, used by physicists, metalurgists etc is the Curie point?
I know that different professions have a habit of bastardizing terminology but shouldn't we be using the proper termonology for it? Who coined the term "critical temp" as it relates to ferromagnetics and why is that term used vs Curie Point?
The term "Critical temperature" has nothing to do with ferromagnetics.
http://en.wikipedia.org/wiki/Curie_point
http://en.wikipedia.org/wiki/Critical_temperature
"The critical temperature, Tc, of a material is the temperature above which distinct liquid and gas phases do not exist. As the critical temperature is approached, the properties of the gas and liquid phases become the same. Above the critical temperature, there is only one phase: that of supercritical fluid."
The above definition has nothing to do with ferromagnetics. (???????)
IMHO this only makes learning that much more challenging when different terms are applied to the same process. A phrase gets misused and then before you know it becomes part of a profession's dialect.
