Civilian for Wave mod and south paw clip
STR
Knifemaker/Moderator
Moderator
Got this in this morning along with some other smaller jobs. Looks like the weather is going to be a nice 48 degrees for a high today. Hopefully we can have a day where I get some shop time in. So far every single day for the last 7 in a row my power has gone off at least once during the day leaving me to wonder how long this time. Maybe today we can get things back to normal. Cross your fingers.
STR
Justin the stock clip will not flip to tip up left hand carry as requested. The pin in the construction of the body of the folder is blocking the clip from seating and to avoid it would cause the clip to block the lanyard.
As a result I'll give you a choice here.
I have these two clips available either of which I can make work I think. The only other alternative is to custom make another or modify the existing clip to fit but it will lose the black color any place I touch it and I cannot get that back once its done so I'd probably have to bead blast the whole clip.
Let me know.
STR
Well, if you can make me a custom titanium pocket clip that will work on both sides, i'll gladly send a paypal payment tonight.
By both sides I assume you mean both sides for tip up carry??
I can do that.
STR
Ok this one is all done and these are in the mail to you now.
I was unable to make the clip work on both sides. the fact is the hole configuration didn't line up to look very good so what you will have to do if you must mount it tip up right hand is simply use the old clip. You said in your note that you didn't plan to remove the clip so I opted to move forward rather than delay another day.
Thanks
STR
