Hi all!
I gave my M43 its first taste of fresh wood and it really was something... I can't remember who said it but it is true, you just can't stop chopping. You cut one, then two, then three and who can count them in the end. It goes so easy and you constantly feel you should cut just one more and you'll be done
)) I will post some pics once I transfer them to the computer...
But something happened when I was cleaning the khukuri after. I noticed it began to make a clacking sound when you move it left to right. At first I thought I was imagining it but then I took it in my right hand and moved it left to right quickly and there it was... Clack-clack-clack! I can't figure out what happened. It wasn't that hard a workout. Ten to twenty minutes tops and I never hit any stones etc. It is a full tang knife so it shouldn't be moving in the handle, right? Best I can figure is that the "habaki" is loose because when I squeeze it real tight, the sound disappears. Either that or the tang in the handle snapped, but that is impossible, right? It cuts normal, and handles normal so if it is just cosmetic and happens a lot, I really don't care but I would not like to swing it some time and have it snap in mid air or the blade falling out or something. I know I am probably exaggerating but I just need to know what that might be. It is my first khuk so I have no experience with actual use their behavior in the field...
So, if you have any ideas, please put my mind at ease... At least what should I check or look for... It's probably nothing but you know how it is, little things drive one nuts, right?
Tnx!
Tnx!
