I just use my fingers, which all used to be longer...
If you heat a glue stick (for a glue gun) you can stick it to whatever you want to sand.
Similar to that, is what they call "dop wax". It's used in gem-cutting to fix a stone to the end of a stick. Heat it up and stick it to what you want to sand. Then simply pop it in the freezer to remove.
Check lapidary supply places. The green stuff is what you want.
Yes. Shellac will work, too. But the glue sticks just peel off.
