Hi,
I am new to folding knife and jut bought Dough Ritter RSK Mk1 with AXIS lock.
I do not sure about using of the AXIS lock and search this forum for a while.
Below is my understanding. If anyone can help me confirm or correct it, is should be very appreciated and helpful.
1. AXIS is mainly for locking not opening. Therefore, usually we open the RSK Mk1 by using our thumb push the knob on the blade for opening and while closing we use our thumb push thumbstud and close the blade.
At first, I understand that for AXIS system when I push the thumbstud, the
blade will swing open (at least on some degree) but that thinking is wrong, doesn't it? We will have to manually open the blade with our hand.
2. Someone open by pushing thumbstud and flicking their wrist to open and close but I think the method in 1. is standard.
3. The blade pivot tension is used to adjust the tension of the balde only.
such as if you want to use your wrist, you shoud loosen it more than
normal. Thefore, if we loosen too much, we may risk the blade falling ??
In conclusion, in order to use the RSK, I should open by using my thumb to
push the knob on the blade to open and use thumbstud to help closing the blade. With this concept, I adjust the blade pivot tension rather tight in order to make the blade secure when closed as much as possible.
Am I right about my thinking above?
Anyway, what shapener is most suitable for RSK?
Thanks in advance
JK
Thanks in advance
JK
