Thanks all!
I used 1084 for the steel (it is my favorite type). I tried to get a look on the polish as close to traditional as I could without using stones as I don't have them yet. I started with 220 grit and worked up to 2000 grit all by hand. Then I took the used up 2000 grit to rub even more. Then I etched it in ferric chloride solution for about 5 minutes. Then I used several types of rubbing compound to finish getting rid of the scratches. I used simichrome last with a piece of leather. Finally, I finished it by rubbing it hard with clean leather (buckskin).
I used satanite for the clay. There are some good articles on this at swordforum.com
Look in the online magazines for Randal Graham. They were a big help to me. I put a very thin coat of satanite on the whole blade letting it dry and then put a thicker coat on the spine down about 2/3's and created the pattern that shows up. I did scrape the spine clean and created the little pattern on it also. Total thickness of the clay on the blade was about 3/16" on the thick part, the edge just had the light coat. I used 5 gallons of tap water to quench it in. I heated it to about 110F and submerged it in the water edge first and kept it as still as posible. I did a 3X draw at 425F for an hour each time letting it cool to room temp before the next cycle.
Not sure when I am going to get this one finished as this one I am making for me and have other commitments to get done. I do have the habaki (copper collar) about 50% done for it though. When I do get it finished I will post some pictures of it.
Ravenclaw
