one thing simple is plain old fireplace mortar from home depot or lowes,...its very sticky but grabs the blade well,...it comes in calk tubes. just coat the areas of the blade you want to stay soft and scrape off any excess,...or you could use satanite... apply the same way, some people have had problems with the satanite coming off the blade in the quench so they wrap some wire around it,...i havent had that particular promlem when ive used it. make sure to clean the blade well with acetone befor applying the clay. the oils from your skin will make the clay not stick as well. another important thing is to make sure the "clay" is completly dry before going to heat treat, i usually leet mine dry for 24hrs and then bake it at 200 deg in my home oven for 2 hrs. also 5160 is a tricky steel to get a good hamon with, you have to be real careful with the temps and clay placement to get the hamon where you want it. its not impossible but not as easy as 1080-1095.
