I picked up several pounds from Darren Ellis. No instructions needed, really. I mix mine with water until it looks to be the right consistency (smooth, but not runny). Then spread a thin layer on a clean blade. Spread it evenly on both sides covering maybe 1/2 of the width of the blade depending on the thickness (thicker blade typically needs less, thinner slightly more). Don't worry too much about creating a fancy pattern as the hamon isn't going to really follow that pattern much until you get pretty good at heat control and clay application. Spread maybe 1/16" or less in thickness. Let it dry or use a heat gun to speed up the process a bit. Fill any cracks that develop. Pop it in the oven/forge to heat as needed per the steel, quench, knock off the clay when it comes out of the quench, and temper.
After that, you won't be able to see anything other than oxidation. Grind the blade clean and smooth down to your final grit, then start working by hand. I go up to 2000 grit by hand typically then etch in ferric chloride diluted with water. Make sure the blade is clean when you etch. After a short etch (I go for around 30 seconds), pull it out and polish away the oxides. I use iron oxide and WD40 on a paper towel wrapped around a sanding stick for this. Polish, etch, polish, etch, until you get the show you want.
--nathan
