I have a general question on cleaning EDC knives. What is the best way to clean out all the lint and gunk that seems to accumulate when the knife is carried in a pocket? I have my little Victorinox on my key chain that could use a good cleaning. The little scissors always seem to stick. I also generally carry a larger Leatherman or Spyderco clipped to my pocket.
Can one clean a knife with soap and water, a toothbrush, etc., then either dry it with a hair dryer or maybe dip it in isopropyl alcohol to chase away the water? Does one really need to clean it, or does keeping a knife oiled enough? I use Tuf-glide myself.
In a related question - a friend was given a Buck Rush assisted opening knife because the previous owner said it was defective and didn't open properly. One attempt at opening it and the reason was obvious- you could here the sand or grit crunch as the blade pivoted. Can the knife be cleaned without disassembling it? Will a liberal application of oil eventually work the grit out or will that ruin the mechanism?
Thanks for any assistance.
