warm soapy water, rinse and blow dry.
. That's it.Chris "Anagarika";16132246 said:Try flushing it out with WD40. This way you don't have to worry about rust, though VG10 is quite stainless.
I usually don't add anything else, only use whatever light minerals oil left behind by WD40.
Edit to add:
The lubricant used seems to be ok. Few possibilities:
The lubricant is thick/low viscosity - it might slow down action but actually working
The lubricant dissolved some manufacturing debris, causing it to move around & hampering action.
That's the reason I suggested flushing with WD40.
Thanks everyone for the help. I'll probably try the WD40 route.
I would NOT use WD40.
That stuff smells forever. And In your pocket.
