Cleaning oils from metal
Hey all,
Not necessarily for knife making, although would be useful information for the future.
My question is regarding getting machining oils off of aluminum. I am associated with a ministry that is having small crosses made to be stuck to an adhesive dot in a mailer and sent out. They are ordered 100,000 at a time and most have to be cleaned in small batches with a commercial washing machine in order to get them to stick and stay in the mailer. It’s very tedious work.
Does anyone have a good solution for doing large batches? My thought was a cement mixer, but what alcohol or solvent do you recommend?
Thanks
I would use a rotary tumbler with stainless steel pins, and a dish soap water solution. So like a cement mixer. It's how I clean rifle brass, and I have a tumbler that can do about 1,000 cases at a time. A 1 yard cement mixer and 20 lbs of stainless pins would probably do an entire batch if I'm guestimating the size of your cross correctly.
Ultrasonic cleaner would work well for that too...
