Cleaning Sharpmaker stones
I have had my sharpmaker for a couple months now and had to clean the stones for the first time. The vid says to use an abrasive cleaner like ajax or comet.
Well, I don't have all that fancy stuff at my place. But I do have Gojo, and it works very well.
I rinsed it but it could probably be used without water available. I just rubbed the stones together and wiped them off. Just a tip.
I use Carberator cleaner, not that I can actually use the thing very
well but it does clean all the old oil and filings off.
Gojo, as in the industrial hand cleaner with those bits of pumice?
Thanks for the advice, my Sharpmaker is due to arrive on Friday! :D
Comet and a scotchbrite pad get them clean in a jiffy. Those ceramic hones are really prone to clogging, and since they are so fine already their sharpening ability drops to zero real quick when dirty.
I try to clean mine after every knife fully sharpened, or after 3 (one on each side) touch ups. Only takes a minute to do, but saves a ton of time sharpening.
Gojo doesn't have pumice in it. It has some light solvents and lanolin.
Lava hand soap has pumice and works fairly well. I like to use stainless steel cleansers since they have some chemicals that loosen up the metal residue along with detergent and abrasives.
I use the recommended method - Comet and a scouring pad. The Comet was $.69 at the grocery store and works well.
Just tried out the pencil eraser.............it really does work!?!?!?!?
Thanks for the tip Stormdrane......pure genius
http://automotive.gojo.com/products/product.asp?cat_id=20
This was the one I was referring to, my father and I use it all time after doing automotive maintainance. Will this work too? The old man stocks tubs and tubs of this in his garage.
The pumice Gojo should work better than the simpler type, but be sure to clean off any oily residue with detergent. An oily residue will make the rods load up faster.
