- Mar 6, 2022
So I am buying sets of springs with their liners and blades. When I go to assemble, I must modify the spring in a couple different ways.
1. As I am receiving them, the springs are hardened but not "reshaped" to reduce to the final tension.
2. Resting on a blade with the blade pin and the middle pin in place, I assume I want the spring to be somewhat even with the scales/liners.
If I put the blade in and the center pin and scribe the spring along the liner, is it reasonable to simply grind that off (right off the bat)?
Once that is done, seeing where the kick makes contact in 2 positions, can I safely assume that I need to thin beyond (towards center pin) to reduce tension as necessary?
I am assuming, that the spring should appear the same in all 3 positions of the blade, Open, Closed, and 90°, yes?
Is there one position that is more critical for setting the spring depth to the scales? At which point do I consider modifying the blade? Knee-jerk says that if it is happy at open but proud at 90° I need to grind the bottom of the tang. And if it is proud closed then both ends of the kick need modification. But, I fear getting into the "leveling a 4 legged chair" situation
I was also considering figuring out which position was the lowest, and simply trying to match the other two to that.
