- May 18, 1999
I think I may have posted this long ago but I'm gonna post it again as if I did it's probably lost in the archives.
To clean up the grooves in a khuk's handle I use artificial sinew which is nothing more than nylon thread that is waxed and -Not- twisted or braided. This enables it to be pulled apart into multiple smaller pieces if desired.
I cut a piece the desired length and re-wax it with the sewing beeswax that can be bought at any good fabric store or sewing center.
Then I take it over to my Grizz and roll it in the grinding dust that's on its table, unless my Barbie has cleaned it up lately.
Then I 'roll' it by twisting it to get it started and then rolling it on my leg. Anchor the khuk in a vise or clamp it down and then place the grit embedded string in a groove and pull back and forth as you would a shoe shine cloth and rotate all around the groove.
This makes a nice smooth and polished finish in the grooves and removes any excess material of most any kind that may have been trapped.
If you don't have a grinder so that you can use the dust I would suggest getting some valve grinding compound at any auto parts store.
It's possible that simply pulling a waxed thread or string through some tripoli or other buffing compound may work just as well.
I did this to my Foxy Folly today to finish getting it ready for the oil finish on the 400 grit sanded Saatisal handle.
Then I went to put some Tru-Oil on the Foxy Folly's handle and found that it had solidified in the bottle, didn't realize it was that
old.
Then I went to use my Formby's Danish Oil and found that it had done the same thing. It was alright three months ago.
I threw them both in the trash.
However someone had mentioned a WATCO's Finish a while back as a possible treatment for horn.
I knew I had another oil finish but didn't realize it was the WATCO brand finish and I happily discovered it to be all right so I'm using it on the FF's handle.
It has always worked well in the past. but I don't know how it would be for horn handles. It is a very thin solution that's not overly sticky like the Tru-Oil and the Formby's so it might penetrate well into horn as it -is- a penetrating oil.
Posting this in the 'Sticky' Tips, Tricks and such thread as well so it won't get lost again.
old.
