Cliff, got a sharpening question.
According to the literature sent with my Busses, it says to use a ceramic rod. I guess I've not payed any attention, but who/where has these kinds of sharpeners available?
I've got stones and a smooth steel, but I want to get the best edge from a Busse when it comes time to sharpen. From your previous posts on the topic, you mention stones will be needed for more aggresive action, but were does a ceramic rod fit in compared to a very fine stone?
Strabs, ceramic rods are very common, just about any large internet store will have them.
You can get ceramic rods in various grits. The ceramic rod I current use is 800 grit, very worn, and leaves a high polish.
My current sharpening method is as follows :
-touch up with strop, first on canvas then leather + Lee Valley CrO compound
if this fails to produce a high quality edge I will turn to :
-a few passes on 800 grit ceramic rod
If this fails to leave an agressive edge I need to remove a little more metal so I try :
-a few passes on a 600 grit 12" DMT diamond rod
-touch up with strop and if necessary, a few passes on 800 grit ceramic rod
Afterwhile even this stops working as I have put a visible secondary bevel on the edge. Then I have to back up one step further :
-SiC wet/dry sandpaper on the convex bevel
-SiC waterstone on the flat bevel
-jump up to finer grits of the same
-touch up with strop and if necessary a few passes on 800 grit ceramic rod
Another method is to use a buffer / slack belt sander, if you have the skill to do this it is much quicker.
-Cliff
[This message has been edited by Cliff Stamp (edited 04-24-2000).]
