Cliff has competition in the test arena but probably doesn't know it.
It is not just Cliff who puts knives to the limits. Many HI customers test their khukuris much the same way as Cliff does. As an example here is an excerpt from a letter I received from a customer just today regarding testing.
My first test is 30 chops into a hard wood stump. Then I chop dark hardwood into kindling. Third, I cut up pieces of tar asphalt roofing material. Then I drive the blade into the stump using a piece of firewood to hit the back of the blade until it is driven fully into the stump. Then I wedge it out. Then I bang the blade into the stump hitting the flat of the blade first right and then left. Then I chop up steel wire wrapped around a wood block. Then I put a brick on two 4x4s and break it two with the spine of the blade. Then I break a cement block with the spine. Then I stab and cut up an aluminum sheet.
A couple of his HI khukuris suffered minor impaction of the blade while chopping the steel wire which the customer expected. Like me, Cliff and others who test severely he expected some damage. It is the extent of the damage that is important. Later in the letter he states, "I can trust my life or the life of my loved ones to these great blades."
These are my kind of customers! I encourage all my customers to test out their khukuris in a similar fashion. I am not physically able to rigorously test every khukuri I send out nor do I have the time so I depend on my customers to help me out. If a knife is going to fail it will almost always fail during these severe tests as Cliff routinely demonstrates and that's the time to catch it -- in your back yard and not when you find yourself in an emergency situation. Once tested and passed the knife has proven its capability and will most likely go on performing for fifty or a hundred years as it did during the test period. If your knife fails then send it back and I'll replace it and keep on replacing it until we find one that won't fail. And that's a promise and a very easy one for me to keep.
Uncle Bill
True Bill, it is nice when people use the knives they have, not just look at them.
I don't do any specific "test" with any type of knife I purchase, but do use them. Smaller knives for smaller jobs and larger ones for larger. I believe in using a knife as it was intended to be used and sometimes a bit beyond. Guess that's why I don't break many knives, but do get years of satisfactory service from them.
Sure, I've had some **** knives over the years that didn't even stand up to what I consider "normal" use. But these have often been cheaper, lesser quality knives than I tend to buy these days.
By the way, I haven't used my AK much, but it sure has done a fine job of pruning tree limbs.
So far.
It's true! I did my first destructive test on my Dhankuta the other night...I was putting some finishing touches on a couple sheaths and I got this "great idea" to whack a piece of wood I had clamped in the becnh vise. Wood was less than two inches wide. I just sort of eyeballed it and let the khukuri fall into the wood with its own weight. Of course, I misjudged the line of movement and the edge came right down on the vise. Folded it about a milimeter! I got the ragged edges out with light sharpening, but now I have a nick in the blade which annoys me. Oh well, live and learn! Duh...
My Custom Kydex Sheath pagehttp://www.geocities.com/CollegePark/Lab/1298/knifehome.html
Palmer College of Chiropractic
On Two Wheels
There is a moral to your story, Chiro, and this is it. Do not chop a vice with a knife unless you are prepared for a little blade damage. Vices tend to be very tough.
Uncle Bill
