Clip for Sebenza
u812
Where can I find a older model thick clip for a large Sebenza?
The Bloodwood my wife got me for Christmas has the newer thinner clip,it is so loose drawing from the pocket I am worried it will slide out on its own.
Thanks
Just called and they are sending me a new one to try.
They said the clips have not changed sense they added the pocket dip.I have got to look at this one more closely to see exactly what is going on with it.I think it may be bowed in the center so not much of the clip is making contact with the pocket.
If this is the case I could most likely fix it myself.
Update:
I took the clip off the other day.The clip did have a funny bend to it that only let a tiny area contact the pocket making it slide out very easy.I got the bend out and it held great.Jump forward to this morning,I had to go to court and up front they have the chairs made for small women-children not big boys with duty belts.I caught the clip on the chair and it bent out about an inch.When I got home the new one CRK sent was in the mail so I took off the old one and fixed it so I could compare.The new one is thicker,maybe the sheets they are stamped from vary a little.I noticed that the original clip had very little spring to it.I even put it back on the knife to try.I could pull it out from the knife maybe the thickness of 2 nickels and it would bend some,enough to not touch the side of the knife.The new one has much more spring to it.
Thank You CRK for getting it in the mail so quick.It will be a great knife for years to come.This is the first time I have had any issue with a Sebenza clip except for the very slight bending out from time to time.
Pic of the two clips.New one is not alot thicker but must be enough to make a big difference
i am glad they were able to help you out in a quick and timely manner. crk is awesome.
