Clip On Sheaths
JK Knives
Moderator
I will now be offering clip on sheaths for all my small knives. These will be a $5 upgrade. No metal is exposed on the inside of the sheath to scratch knife, it is sandwiched between two pieces of leather.
Sweet! Great option for a sheath. I made one once. Kind of a pain in the butt the way I stitched around it, but it came out alright..... the third time :) Handy as hell. I love clipping them on and not having to even have a belt!
Is it possible for you to retrofit existing sheaths with this without having to take the sheath apart? I imagine if you had to do that it would be just about as expensive for a new sheath right?
Looking good, John :thumbup:
~Noah
You would need to cut all the stitching and basically start over.
This is a good idea!
One of the only non-Stomper EDC knives that I use in PA I use especially because of the versatility of a boot clip.
When you have time, you can make a leather sheath with the clip for my new Buck Vantage Pro. I can send the knife if need be.:)
Clip Idea- Using the neck/pocket sheath for my EDC Anniversary I took a small metal clip(covered with a leather skin) from an old I-pod holder. Using a chicago screw I attached it to one of the existing holes in the pocket/neck sheath along with a piece of leather sandwiched in the clip so it would be flush with the outside thickness of the sheath. The metal clip already had a rivet hole so I bored it out to match the sheath hole. The clip is mounted so it is parallel to the handle, but slightly shorter. When clipped to the pocket about 1/4 of an inch of the handle is sticking out of my pocket along with its short lanyard knot. It is easy to resheath in that position and the sheath is out of sight. I wore it to work today with 511 trousers and it worked great. our home computer went down and this loaner will not take the camera memory card so no picture at this time. I'll post a pic when I can.
It actually fits pretty good in the 110 sheath. It is just a tad loose unless we put the flap on it too.:thumbup: Like if I stood on my head, it might fall out.:D
The knife I mean ;)
