high desert
- May 20, 2009
What is the bit (style and size) for the screws on the clip? Thanks
OK, so what you're saying is.....you don't know.Depends on the knife.
Paul
- Most older three screw clips use small phillips screws and take a #1 phillips driver.
- Two nickels are the best thing for barrel bolt clips.
- Newer three screw clips use T-6 Torx screws.
- Most of the newer single screw wire clips use a T-9 Torx, although a few use a T-8 Torx screw.
- A few of the older, high end models don't use any of the above.
My Personal Website ---- Beginners Guide to Spyderco Collecting ---- Kiwimania ---- Spydiewiki
Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
WTC # 1458 - 1504 - 1508 - Never Forget, Never Forgive!
It's easy to grin when your ship comes in and good fortune and fame are your lot, but the man worthwhile is the man who can smile with his shorts twisted up in a knot. - Morey Amsterdam
I repositioned the clips on a Manix 2, Persistence and Endura 4 and used a T5 Torx bit, or so the label on my screwdriver says.
Am sure that's true, but it's a bit deceptive too. They may, for example use half a dozen or more different combinations of length and size, all of which have T-6 Torx heads. Even barrel bolt come in two materials, and possibly two lengths of each, to accommodate different handle thicknesses. Right now, at least 90% of all Spyderco fittings are Torx, and the only sizes I've ever encountered are T-6, T-8, T-9, T-10, and T-15.From a conversation with Charlynn in W&R one time, I was told that Spyderco uses over 45 different screws in their knives. It will probably help to be a bit more specific about which knife you mean.
You are lucky you didn't strip the heads of your screws. T5 is too small and Spyderco doesn't use any T5, mostly T6 for the smaller screws on the handle and clip.
