Are the screws that hold the clip the same size on the Large and Small Sebenza? Since the slabs are a bit thicker on the Large, it appears that you can replace the screw without the insert. On the Small, it appears the screw could contact the blade.
The large screws are longer but you can use them. If you put them on a small sebenza the screw will poke out some and be visible when you look inside the knife.
I can see as much screw protruding inside the handle on the Small (with the clip on), as I do on the Large (without clip or insert) with the screw replaced.
