- May 14, 2010
Closed
I'm a .41 Mag nut and as much as I'd like the .41 Ruger I'd be concerned about the thinner chamber walls after that modification if reboring/chambering a .357. You could probably get a .41 barrel made but it would be pricey. I have a couple IMI Timberwolf Carbines and if I win the lottery I'll have the .44 converted to .41. Have you considered a Marlin lever action? They made a few in .41 mag and you can probably still find one for a lot less then it would cost you to buy/convert another rifle.
I think the .357 will be a better rifle than the .41 due to the relative powder to bore volume.
You'll get way more velocity from the .357, and a rifle is for longer ranges which means you want velocity. Also, a smaller diameter tends to mean better aerodynamics. You can push 180gr .357 handloads pretty fast out of a rifle, or go with 158's or the leverevolution's for longer range... Keep the .41 as a pistol round - it's awesome for that. That's my opinion.
Would a .41 rifle be cool? hells yeah. Better than other options? eh.
Might as well have one gun of your pair at hand that takes easily found factory ammo...
I would think that the .357 and the .44 that ruger makes are both milled from the same size blank. if that is the case, the barrel should be fine for .41 mag if it can handle .44 mag.
I'm not a fan of lever action, from what I have heard, bolt action is always more accurate (the shooter is the bigger issue I am sure).
I'd say it's more about having rifles that match my revolvers for the sake of fun.
People have been rechambering rifles for about as long as there have been rifles, so it can be done. There are not many people who can rebore and rifle the old barrel but any decent gunsmith could make a new barrel from a .41 blank. You also have to modify the bolt face and extractor. The problem is that this can be relatively expensive for what you end up with. You would be better off to buy a rifle already chambered in this caliber and it would probably cost less than the conversion cost.
If I had a Ruger revolver in .41mag I would sell it for a Ruger in .44mag or .45Colt and then get the companion rifle in that caliber. I understand that .41mag is a good caliber but IMO .44mag is just that much better and if you reload appropriate ammo the .45Colt is the best of all. If you had a S&W revolver I would say stick with .41mag but the Ruger revolvers are so much stronger that it takes a larger caliber to get the best of them.
