Hi forumites,
I hereby present some pictures of both dismantled Al Mar and Böker Applegate Fairbairn daggers, along with the mods that warranted their disassembly. Enjoy and learn!
It all started with an Al Mar production prototype that arrived from overseas with hairline fractures in it's cheap, black plastic scales. In order to prevent further handling damage, I asked a friend at Böker Germany to send me some desert colored scales. Although of a different era and manufacturer, I had roughly measured both productions up and they seemed to be to almost identical specs.
When the scales arrived, I could even confirm that no handwork was needed, except for some minor filing on the internal scale pins. I used the accompanying unmarked black guard + screws to mod a Böker ltd. edition that had been a bit to shiny to my taste.
Couldn't have been happier with the final results!
Al Mar production prototype with exposed tang and soldered crossguard. Note the heat discoloring on the tang. Alongside are it's new Böker handle scales with removable weights. I left the weights out for a better fit. Without weights, the balance shifted to just below the guard, instead of being butt-heavy.
Al Mar prod.prot. rehandled with it's original handles exposed. Note the glued leaden rods that add minor weight to the featherweight plastic. These weights could be removed, but I wouldn't risk tearing the plastic, which is thinnest at the grip-enhancing grooves (= most prone to cracking, as happened with these)
Böker Anniv. Ed. with tang exposed and orginal fittings displayed. Neither the Al Mar nor the Böker AFs extend fully up to the pommel: their tang ends just above it, leaving the lanyard hole unsupported.
Current collection with modded models added. L2R = Al Mar, Al Mar (MOD), Blackjack, Böker (MOD), Böker
