C'mon Just The Tip...
I keep a PM2 in hiding and I use another for EDC..but I am constantly touching up the tip. I'm sure that I'm not alone but I want to know who else goes through this regularly?
I often end up having to take one of my users back to the wetstone only because of a slightly damaged or dull tip. I guess some people would say I'm abusing my knives.....
I'm ok with using my "user" work knives hard. That's what they're there for. I also have some nicer, lighter knives I carry on the weekends, and those tips are needles....and they pretty much stay that way.
Sounds like you're using it prety regularly, but it doesnt sound bad!
Yea its not bad.. The factory PM2 tip is just a bit delicate for my taste. Pretty much my only complaint though. However once the original tip is broken off, the next one you grind is more beefy and user friendly.
Quit letting the tip of your blade slip off the sharpener at the end of your stroke. This will round the tip eventually. Stop your sharpening stroke with the blade tip still on the sharpener.
Observing how I and others use knives has taught me things. One big thing I've noticed is that almost everyone I watch cutting things seems to instinctively use the tip of the knife the most. They pierce almost everything that can be pierced before cutting it. Which, if you study how you cut, actually makes a lot of sense. For example, try to cut open a cardboard box without piercing and without sliding the blade down a fold. It can be done, but you have to start at an edge and do a slice cut at that edge. Then it's easy once it's started. The piercing is all about getting the cutting edge in contact with the inside of the media. I'm making way too much of this.
My key point is that the tip and first inch or so of blades get used and abused WAY more than the rest of the knife. So it needs sharpening more often and more attention when you do a full sharpening. I notice this on my EDC blade a lot. I spend 2 to 3x the time on the first inch or 1.5 inches than I do on the rest of the blade because that part gets the most use.
Brian.
I almost always like to regrind my knife blades so they have (wait for it...) a penetrator tip.
;):D:cool:
