If a maker uses CNC to make their knives, does that count as a custom knife?
Uh oh.....here we go again..
CNC is here to stay. I own and use the heck out of two CNC machines. I can assure you, just because a knife had some operations done on a CNC machine, it still requires a lot of hand work.
Also, the acronym CNC doesn't mean "can be operated by anyone with perfect and repeatable results" . Still a lot of skill required......as evidenced by the large pile of bad parts and broken cutters I have![]()
Hi Severed
What about the other questions?
Lots of very well known makers who employ all of the techniques I mentioned.
Les Robertson
Custom Knife Entrepreneur
www.robertsoncustomcutlery.com
**********************Hi Blazen,
Knives that are made using a CNC are in fact custom knives.
custom yes, but not handmade
Question, if a knife maker outsources his heat treating is it a custom knife?
Yes
Question, if a knife maker uses someone to cut out his blanks on a jig saw is it a custom knife? No
Question, if a folder maker uses "jigs" to make the frame of his folders is it a custom knife? No
Question, if a maker uses a hydraulic press to create a pattern in the Damascus is it a custom knife? Yes
Remember, the CNC basically does the "blank" work. It is the skill of the maker to finish the knife that turns it into the finished product that is a custom knife. Yes, thus semi-custom
Les Robertson
Yes, it IS indeed a custom knife!!!!If a maker uses CNC to make their knives, does that count as a custom knife?
