Cnee's custom clips for an Obenauf folder.
STR
Knifemaker/Moderator
Moderator
Cheng I was not sure the copy I made just like the original or close would do what you requested here. As a result of not knowing I made a low rider to fit also. Due to the problem you have it may be the only alternative.
Cheng's problem is described best by a visual for you guys wondering. This is an Obenauf 'Big Bandit' folder. Apparently there is not enough elevation for the clip to slide on and over the rim of the pocket as effortlessly as he would like and I can see why from these pictures. I don't have the knife here but the clip is here and I made a couple with greater elevation to see if one will help him out. Guess we'll know when they arrive to him.
Thanks for checking it out.
STR
Thanks very much STR. I really appreciate STR's commitment to help us out in any way he can. I anxiously wait for the new clips to tryout...
Cheng-Lee
STR, I received the 2 new clips. The low rider works great! Thanks very much for your help!
Pix???
You gotta show us now. :D
STR
Sorry for the delay... Here are the pix showing the Big Bandit with the Low Rider. Which clip looks more sexy? ;)
The finish matched up better than I had hoped. It looks like its sprun a bit much since the clip is not parallel with the body but so long as its not in the way of your grip or uncomfortable thats the main thing.
Thanks for the pics. I thought the low rider was the only way to really make it work for you with that G10 overscale on it.
STR
Yes the elevation is a bit short for the thick CF scale. So I opened it up just a little and it fits nicely. Works great! Thanks.
