If you don't need to re-profile very often, the easiest and cheapest solution is to just wrap some wet/dry sandpaper around the rods. Something in the 220-600 grit range would work very fast on most steels. The more firmly-attached the paper is to the rods, the cleaner the results will be, and the more aggressively it'll work. Could also use hardwood dowels or metal rods or tubing of the same diameter, to which you can dedicate the sandpaper when you need it. Some temporary spray adhesive of a type used for woodworking works well. Spray the back of the paper only, and let it dry until it's tacky but not messy. Then just press it onto whatever surface you use. Holds well until you need to change out or remove the paper, then it peels away fairly easily, leaving little residue behind. I've been using sandpaper on glass recently, attached in this manner. Works great, in a stropping fashion (edge-trailing). Edge-leading can be done also, but you need to be extra careful not to cut the paper.
David
