I still use press cutting photocopy paper (then newsprint) as a final test for burring - no matter how coarse the final grit.
I choose the final grit for the work being done, then use the paper test to insure the burr is removed from the "teeth" of the edge. Going back to the actual cutting task is the real test, since it is easy to pull alot of the coarseness off the blade with poor technique with the strop.
IMO - you are on a real growth path once you start "coarse edges perfectly finished" - because you can suppliment press cutting with a small component of slice cutting (in difficult jobs) and NOT have to increase cutting force. If you can keep the applied force low, you can remove additional supporting material from the edge without durability problems.
MAT
