Hello everybody
Ok, here is a progress report and some questions about HT and coating. Going slowly, as I can only work on knifemaking while on vacation or during a long holiday, because I do not have a shop in my apartment. The shop I use is actually 600 miles from where I live
The first pics were taken before HT. You can see some droplets of water because it was raining. I usually build a temporary forge outside the house, but it rained during the last two days of my vacation and you cannot imagine how p*ssed off I was. I improvised something under a roof.
Sorry I did not have a measuring tape in inches at the time, but if you manage to translate from metric
, you will see that the overall length of the knife is about 9.5 in. Therefore it is a little too big for a necker. I scaled up the izula's shape. I have a fetish for big knifes and the next one will be certainly bigger
I wasn't very sure if the knife had hardened properly but I went ahead and tempered in a hot oil bath.
Strangely, there was almost no scale formation. I had lots of scale on my previous knives. I don't know if that is because of the steel I used or because I injected less air this time. Maybe the charcoal was different.
I work for a university, so I took the knife to a lab where they tested its hardness for me. Measured at three points, it yielded 58-59 HRC values. Now, I believe that since I tempered at only about 375F, I could have done better with that steel (5160H). Good enough for my third HT though. I was afraid I was going to get a horrible value, like in the low 50's.
The surface of the steel had some weird pattern after HT. They remind me of bubbles.
Q1: Are these "bubbles" normal? Does it tell anything about the HT process, such as decarb/wrong temp, corrosion, problems with the quenchant not wetting well? I used sunflower oil preheated at 140F for quenching.
Before I get the usual suggestion of getting a proper oil, let me tell you that that supplies are very hard to get here. They are used in industry but they are sold in large quantities only. They would not sell me a 7 yard bar of 1080ish steel because it was too small an order
. I found a place where they sell single bars of 5160, which is what I am using now.
Today, I used a small blowtorch to give the handle and the spine a softer temper.
Tomorrow I will start polishing it and then I will sharpen the blade. They don't sell plastidip here either but my bro is visiting the states now, and he'll get me some (provided the TSA does not consider it a WMD).
Q2: Does it matter if the handle is rough or smooth? My concern is that if I polish the handle too much the coating may not stick. I plan to clean clean the surface with acetone before coating.
Will post a pics when it is finished.
Best regards
