Thanks for detailed feedback!Here, my scientific opinions
The code 4 is a little too slick for me, but had a very robust blade and is pretty light amd thin for its size. Handle feels solid and triad locks up solid. Handle fits me pretty well, but is slick. Mine came with a very very well tuned triad lock, I can easily flick it open and 1-hand close it, something which I hesitate (or have trouble) with other cold steels.
Minigrip feels tiny in the hand but grippy. Slightly cheaper feeling due to the material, and doesn't have a slicey blade like the code 4...it's a small thiccboy. Fun to fidget with and very nimble in hand due to the more neutral Handle.
Good luck
Full size grip is just 5€ over the price of Code4, but I prefer something small, that being said I might change my mind when I see it IRL.Dergyll summed it up well. Do you have the option of the Cold Steel (CS) Ultimate Hunter black G10 or the CS American Lawman for a few euros more? Both the Ultimate Hunter (UH) and American Lawman (AL) are similar in size to the Code 4 but both have G10 handles so you avoid the slick feeling handles. I prefer the UH over the AL due to fatter handles (I have a big hand). I find the UH more comfortable. If you wear a small or medium size or want a thinner knife, nothing wrong with the AL. Either way, for a few euros more, so get a similar knife with G10 handles.
Also, the Minigrip is quite a bit smaller than the Code 4. Are you maybe looking at the full size Griptilian? It is similar in size to the Code 4.
Now this is the kind of comment I was looking for.Go with the Benchmade. Cold Steel warranty support sucks now, and while the Code 4 looks flashy and is very robust, the aluminum scales are slick and there are some sharp corners to it when the blade is closed. Also, the pocket clip is tight so it’s difficult to take out and out in pocket. I would rather have the code 4 if I was stabbing holes in the hood of a car.. and since I don’t do that, it’s the Benchmade for me.
It's sadly not available here...If you're considering a full size Griptilian then you might want to check out the Ritter Hogue.
Code 4 has a bit better steel and would carry better, but if it's anything like Voyager I had then one handed opening and closing kinda sucks.Code 4 is the better knife for a better value , IMO .
Tri-ad lock , S35VN , Aluminum handle that carries thinner and lighter than most Cold Steel
The grip is sufficient for most uses , because of the ergonomic handle shape .
I have an older model CTS-XHP , the handle finish is not nearly as slick as expected and once a full grip is achieved , it feels solid and secure .![]()
The full size is too much knife IMHO. I’ve owned both, several of them, and the small never lacked for cutting ability. The large is a bit much. I wish there was one in between honestly but there is benefit to the small size of the mini. Easily pocketed and easy to control.I just checked and full size Griptilian is same price as Code4... I might go for that then.
I'm mostly concerned about one handed opening. I mostly need my knife while I'm doing something already.The full size is too much knife IMHO. I’ve owned both, several of them, and the small never lacked for cutting ability. The large is a bit much. I wish there was one in between honestly but there is benefit to the small size of the mini. Easily pocketed and easy to control.
If ease of opening is the main concern, I’d further suggest the sheepsfoot mini grip with the thumb hole.I'm mostly concerned about one handed opening. I mostly need my knife while I'm doing something already.
With triad lock - that's hard.
So far it's been easy with ESEE Candiru as I just reach for my pocket and pull while pushing the sheath with my thumb and that's it. But then I sometimes have to hold it with my mouth like a pirate or put it aside until I have both hands to return it to sheath that stayed in my pocket
But yeah, a stainless folder to go along with rugged fixie would be ideal.
Being robust isn't much of a factor as I got the ESEE for such tasks, and I doubt even Code4 can survive such abuse. So main concern is one handed opening.
ThisGo with the Benchmade. Cold Steel warranty support sucks now
Sheepsfoot will probably never enter my pocket... I prefer my blades pointy.If ease of opening is the main concern, I’d further suggest the sheepsfoot mini grip with the thumb hole.
