- Sep 11, 2014
Hello to everyone in the forums!
Here is the first complete prototype of a folder design I have been working on for a few years. Took me a long time to have a working prototype because I needed to acquire the right machines for the job and also to learn and practice a lot in machining. It has been quite a journey and I learned a lot. I will be making some iterations in the design after the next two pieces that I am about to complete in the near future.
The specs are the following:
Acid stonewashed Elmax blade at 4.1mm thickness and 61-62 hrc with flat ground recurve/tanto style lines.
The whole handle is 6al-4v Titanium (4.4mm) contoured, bead blasted and stonewashed.
Pocket clip and backspacer are also grade 5 titanium that were blackened. All the screws are also made of titanium some of them bead blasted and some blackened.
Stainless steel ball bearing with hardened steel washers for the blade to ride on. The detent is ceramic and hidden. The stop pin is 5/32 inch diameter.
Lastly the lock side of the frame has been carbidized to last longer and to eliminate lock stick.
Here are some pics of the finished product. Let me know what you think and any input you might have to make it better.
IMG_8586 by Panos Evripiotis, on Flickr
IMG_8585 by Panos Evripiotis, on Flickr
IMG_8590 by Panos Evripiotis, on Flickr
IMG_8597 by Panos Evripiotis, on Flickr
IMG_8602 by Panos Evripiotis, on Flickr
IMG_8610 by Panos Evripiotis, on Flickr
IMG_8611 by Panos Evripiotis, on Flickr
IMG_8617 by Panos Evripiotis, on Flickr
IMG_8614 by Panos Evripiotis, on Flickr
IMG_8628 by Panos Evripiotis, on Flickr
