Coffee Can Forge
I thought I'd try something a wee might different (for me that is). I got real tired of building a fire in my "pit" and put off firing the blades that I'd layed up, so what's a guy to do?
It sort of tickled the back of my mind the other day when I was cleaning up the shop. "About 20-30 large coffee cans-- check. Some scrap pipe/conduit--check. This flange/ that dohicky--check..... I've got it!
Let's see, what to use as an air source.....Oh Yeah, that old oxygen concentrator from my Home Care days... That'll do-it! A trip to Wally World for some charcoal, and I can get started!
Oh boy did it work!! I was able to get 17 blanks up to non-magnetic using 2/3 of a 20# bag of charcoal.
Draw backs: the O2 concentrator has only 8-10 liters of gas out put at only 10-12 PSI (that brings purity of oxygen output into the upper 60%'s) so instead of blowing through and clearing ashes out, there were hot, or "sweet" spots that I would have to manuever the blanks to. I also had to fan manually from time to time.
Fix: I spent today disassembling the concentrator salvaging the compressor assemlby that has a raw output of over 100 l/m at 25-30 PSI. A little retrofitting to the "forge" should do the trick.
I'll post a follow up after I get the forge MK II fired up.
Jim L.
I hooked up the compressor and boy-howdie!, does that thing get HOT! I did one blade with it already, and the carbonized finish is beautiful. It sure burnes the cans up, though.
I'll have to start the MK III in steal andconcrete.
Jim L.
