I have used old saw blades and have had some mixed results, The blades that you can sharpen are pretty decent. I have use old rasps and files before with good success but take note not all files and rasps are good material, I heat them to 1500 quench in water put them in a vice and take something " crescent wrench" see if they snap. If they snap they are good steel if they bend they are only case hardened and are scrap steel. I anneal the files and rasps by bringing them back up to non magnetic around 1450-1500 degrees and put them in a bag of lime or put them on a large piece of steel that I keep warm for a while with a propane torch to cool slow. Cooling them slow is the trick, After a while when they cool down you should be able to cut with a hack saw or what ever you wish. Normalize them after grinding before heat treat, Heat to 1650 let cool to black, Heat to 1550 let cool to black, Do again at 1450, 1350 after this you can harden and temper, I usually temper at 400 degrees for 2 hours two times. All the Belota Rasps I have tested have been good, Hope this helps and I'm sure there are others who will weigh in on this issue.
