Cold Steel and Moore Maker - Camillus Legacy
Planterz
Іди на хуй Путін!
I picked up a couple of stockmans a couple weeks ago from that auction site. One is a Cold Steel Classic Junior Stockman #54MS, with Carbon V steel and jigged black delrin handles. The other is a Moore Maker 3300 in carbon steel and smooth yellow delrin handles. Both 3 1/4" closed. Both were made by Camillus. In fact, the gentleman I purchased them from worked for Camillus for many years and purchased these knives in number at the auction when Camillus closed their doors.
Excuse the mediocre pictures.
Moore Maker
attachment.php
As you can see, there's more than a coincidental similarity between the Cold Steel and the Camillus made Buck 303. I think the clip blades were made from the same tooling, as apart from the swedge on the Buck, they look identical.
attachment.php
However, the spay and sheepsfoot blades, while of similar shape, are quite a bit thicker on the CS.
attachment.php
In fact, the Cold Steel is quite the lardbutt when it comes to thickness. (Buck left, CS right)
attachment.php
Compared to a Case 6344 (exactly same length), the Cold Steel is downright fat.
attachment.php
It's as thick as my 3-spring Buck 301. This makes for a small, but still very substantial knife. Beefy, yet still very pocketable.
If you check the auction sites, you can sometimes find these up for grabs. Usually under $40 and compared to the Cases at that price, these are much better made knives. It's too bad they're not made anymore.
I have a Camillus Junior Stockman that is identical to your Cold Steel knife, the exception being the shield.
Here it is with a large Cold Steel stockman. The handle material is the same for the two knives.
Here's the large Cold Steel stockman and a Camillus Roughcut stockman. The family resemblance is unmistakeable.
- Christian
I have a Camillus Junior Stockman that is identical to your Cold Steel knife, the exception being the steel.
I read somewhere (I forget where) that you could pop the shield off of some Camillus knives and it'll have Buck's hammer/nail logo on the other side.
Interesting. I mistyped my first post though, I mistakenly typed steel when I meant shield. My Camillus Junior Stockman has Carbon V blades, assuming all the blades are made from Carbon V as the master is.
- Christian
