- Sep 2, 2008
Hi folks, I'm hoping someone can help me with this problem.
I purchased a Cold Steel Assegai a few years back, and stupidly tried to force the provided shaft on the head, only to discover the tapered section wasn't sized correctly. I could not fully seat the shaft into the head, leaving a gap. I thought, also stupidly, perhaps I could just shave down the remaining area to help get the head fully seated (which is why the gap you see below is unvarnished). So, now I have a shaft that's wedged into the head and I can't figure out how to get it off safely (I have minimal tools at home, unfortunately).
I'd like to either get a Cold Steel replacement, or, more ideally, I'd like to make or have made a new shaft for the spear. If a new shaft is made, I'd like to give it a slightly oval cross-section, so I can index where the edges lie from the orientation of the handle in my hand. That way I won't have to look at the head to know where cutting orientation is. Again, I don't have the tools for such a project though, not yet. So for now, I simply want to remove the head. From there, I'll probably just get another shaft from Cold Steel, since it's already properly tapered for seating (but next time I'm checking if it needs sanding down first).
Any help and advice would be appreciated! Thanks.
ETA:
I've been thinking I'd just saw the bulk of the shaft off, then devise a way to either pound or twist out the part of the shaft still lodged in the head.
ETA:
