Have you tried chopping hard with it? You will discover two things:
1. The handle texture will give you blisters (unless you wear gloves or have calloused hands!)
2. The blade gets stuck / wedged on heavy chops into wood. This is because the flat V-grind will cut deep, but then get stuck. The convex grind of a genuine khukri (like from Himalayan Imports) does not get wedged as often and helps to break wood.
However, the CS Ghurka Kukri does look cool and handsome - but I like to use my knives.
