- Oct 11, 2012
I saw this video on one of my friends YouTube Channels. What do you think about this?
This was the LTC (eg the machete version)The Carbon V stuff hasn't been made in years, either. That said, it could be a bad batch/one off. A traditional khukuri generally has a very soft tang to prevent that sort of failure. However, it is not uncommon for an oopsie to happen where the kami (bladesmith) splashes a little water too close to the tang and hardens what was supposed to be left soft. I've often thought the stock of the CS khuks was a little thin for a blade that is going to be swung hard and torqued on a lot. I'm also guessing that they aren't differentially heat treated, but maybe they are. You have to walk a fine line between too soft that it will bend the thinner stock and too hard that it will shatter under stress.
Glad no one was hurt.
The LTCs were Carbon V. The machetes are 1055.This was the LTC (eg the machete version)
n2s
True, there were no Cold Steel machete back then, and the LTC was the machete-like knife. Still it is a relatively thin blade which was not intended for processing trees trunks. I suspect metal fatigue from repetitive lateral over stress.The LTCs were Carbon V. The machetes are 1055.
n2s
