I have a Master Hunter in carbon v, it is VERY balanced, the carbon v used to be made by Camillus (I think it was L6 steel). This knife is really hard to beat for a hunting blade, hand doesn't slip on handle when wet, distal taper blade (flat grind), takes an incredible edge & holds it well, easy to sharpen, and it is the best balanced fixed blade I have! They also made a Master Hunter in AUS 8 steel, and w/guthook. I have no clue as to what the current production Master Hunters are like, i've had mine for MANY years. Living around salt water... the old AUS 8 model might be a better choice over carbon v (carbon v rust pretty fast if not oiled). You might still be able to find either older model if ya look around on the web, I think they would be of better quality. Hope this helps ya out a little!
