- May 17, 2006
Is the Cold Steel Master hunter full tang? How does it rate as a survival knife?
In Carbon V, the Master Hunter was a great knife.
Now, of course, Carbon V is no longer available.
So Cold Steel makes the knife in
"San Mai III"...which is apparently VG-1 stainless clad in 420 stainless.
Wonder how the "San Mai III" cuts, sharpens, holds an edge?
I have both the Carbon V and the SanMai versions of the Master Hunter. Both have seen pretty extensive field use and both hold up well. The Carbon V is a little easier to sharpen it seems but the SanMai seems to hold it's edge a little longer.
As the other fellows have said, I'd not worry if I found myself in a sticky situation and 'only' had the Master Hunter (either model) to take care of business with. Admittedly, it would not be my very first choice for a survival knife, but it wouldn't be far down the list, and for the $$$ I doubt there is a better choice.
Edit to add : The SanMai version is a little thicker in the blade than the Carbon V so is not quite so good as a deep slicer, but the difference is minimal.
The Master Hunter is definately full tang. VG-1 San Mai III has worked out greatly for me, it holds a VERY strong edge.
