I have a Night Force and for the life of me can't see how anyone can bust this knife in hard use.
The Cold Steel zytel handled LINER LOCKS are VERY STRONG.
The fold-over style face of the lock has 3x the surface area of most liner locks and is heat treated steel.
The liner is almost full width of the handle and is nested ala Spyderco with 6 screws holding it in place. There is a heat treated metal frame under the other handle slab also. Metal screws into metal.
There are no rivets.The pocket clip is metal and screws into a liner.
It appears they used threadlocker on the screws also.The plastic is just a cover for the liners, not a true load bearing component as the stop pin is held in by the steel inner frame.
The handle is FRN. That doesn't mean it is necessarily weak (remember, it is supported my steel liners)
The exoskeleton may not be as strong as metal, but is probably strong enough for the job (and price point) at task.
For hard/moderate use, I would much rather have a Night Force than any other Sub $100 dollar Taiwan liner lock. Pretty tough cookie.
Cliff's comparison to the Voyager is pretty weak as they are completely different knives. What you cannot see from the pictures is that the Night Force has a fully supported metal frame, the Voyagers do not. This knife has 6 screw construction into hardened metal posts for stability. The Voyager does not.
The only negative I have of this knife is the blade steel selection.
It is also a little heavy due to all the metal used in its construction.
When knives like this fail, they usually fail at the screws or the lock face. This one doesn't look like it could fail at the lock face because of the width of the lock, and the screws holding it together are large and many.
This knife is not a weak sister.
