- Apr 25, 2005
Hey all...
almost finished mounting up my poll axe from cold steel and thought I would share what I did.
Ordered it through their ITSpecPro website for $38 for shipping and all.
arrived about 8 days later in two seperate packages. One for the shaft and the other with the head and langlets and screws for assembly.
So as you can tell it comes powder-coated black. Which as far as my knowledge of original poll axes go, I'm pretty sure they didn't come like that.
So in that vain I wanted to get the coating off... so got some sandpaper and went to town; and boy I went to town... many times over. The powder-coating is pretty durable and thick which makes it a pain in the @^%#$ to get off.
Heres a scale shot to give you an idea of size and of my sanding efforts.
To top it off the whole head is cast and then welded to a short collar as you can see in the first pic. This is not a big issue as its an impact weapon and I got it for dry handling and looking fearsome on my wall
anyway, so durablity is not an issue but its built like a tank so I'm pretty confident it could handle some serious abuse. I mean come on... its from Cold Steel!
The only downside to casting is the small imperfections in the steel and the way the powder-coating gets in there and it is super hard to remove by hand. So I went out to the hardware store and bought one of those small wire brush wheels that fits in a drill. Much better and faster at removing the coating, wish I had done it from the beginning!
you can see the difference in this pic... the axe side has been done with the wire-brush and the hammer side only sandpaper...
you can also see the welding of the collar. I took a metal pipe-cutting saw and removed this part and I think it looks much better and removed some excess weight as well.
So after taking off the powder-coating I turned to the staff. I had some left over dark cherry and ebony stain from other projects. I was going for this "used battlefield" look...
So I took the dark cherry stain and to make it a little more darker, I added some ebony stain to the mix and now its a very, very dark reddish-black... very authentic looking if I say so myself.
So now all I had to do was mount the head and for that I just hammered it on. Mine was a very tight fit but I think thats a good thing and sometimes I had to use my 15lb dumbbells as a hammer. To prevent dinging and deforming the metal I covered it with either a folded towel or old leather glove.
and here it is stained and mounted...
I originaly wanted the head to be a little lower to facilitate handling as it doesn't have any counter-weight to balance it out, but it was so hard to get it flush with the top of the pole and I was afraid if I kept pounding it on I would damage the ash pole. I've heard the wood that comes with some Cold Steel products is crap but the one I got seems to be fine and solid. its round for about the first 1/4th of it and then planed flat on two sides for edge orientation during handling.
On a side note, I almost just took the haft and made a Japanese tetsubo'. For those who do not know what that is... heres a nice example...
It would be a good base to make one from if your looking for a uncommon Japanese weapon.
To attach the langlets I didn't want to use the black screws that came with it as that would just look wrong and cheap to boot. I tried to find nails with a more rounded head to represent real rivets but alas... none in the size I wanted. So I settled on just bright nails that were 1 1/4" long and used tin snips to cut them to about 3/4" long and nailed them in.
Heres the finished poll axe...
and full length shot...
its about 6' overall and a hefty 12lbs...
Its very solid and could generate some serious power with this thing but of course, lacking any counter weight, recovery is crazy slow and ponderous. At the time I thought adding the langlets would make it look really good while not adding too much weight, but upon mounting them I realize I don't like it as much as I thought I would. Mostly because it adds too much weight and makes it more of a workout tool than a battlefield weapon.
I'm thinking of several solutions to this, one being to remove the langlets and re-attach them to the bottom of the haft. The other is maybe grinding some material from the langlets and drilling new mounting holes. So we'll see how much work I want to put into it later on down the line.
Overall, for $40 and a little elbow grease, you can have a serious weapon that, with some modifications, I would not hesitate to take to the field with back in the day.
Comments and questions are welcome.
Best,
Brian James
Best,
Brian James
