cold steel spartan
Ive been wanting the cold steel spartan for a while now and i know how strong the lock is but i don't really know much about how well the blade can maintain its edge and the point. Could anyone tell me about how the blade holds its edge and point? thanks
Edge retention is on par with other AUS8, however the stock is pretty thick, so reprofiling is a pain
Tip is thick and holds up well
Most important thing is I'd say find one to hold in your hand. It is bigger than you think, which is why I had CM mod mine
oh so how is the rust resistant? and did you mod it like that because so you have more than one place to hold?
It isn't very rust resistant. I got rust spots on mine even though it had a corrosion inhibitor on the blade. The bead blast finish is probably to blame there.
The stonewash finish on the new Voyagers is much better in this regard.
The AUS8 is bead blasted which makes it a bit of a rust magnet, but polishing the blade is fairly easy and helps alleviate the problem.
could you tell me how to polish it? sorry I'm not very smart, I'm only 13
Get sandpaper of multiple grits, start with around 120 (normal sandpaper), then move to about 600, and then 1000 and then finish with 2000 and flitz
Powernoodle, I always love seeing that knife
Dremel cut off wheel and clean up with my belt grinder.
I feel like I've stolen an idea now, but I liked that Fresno Felon special edition too much and had to try it with my Spartan.
My handle's a bit different though - I added another finger space around the pivot, so I can hold a bit closer to the blade if needed.
Great job on that!
