- Aug 27, 2004
I pretty much quit buying from Cold Steel a while back and said that the Ultimate Hunter folder I bought (great knife by the way) would be the last for a while. Well, a while came and went what can I say. The truth is I've never had any problems with Cold Steel knives and the ones I've owned have been very well made and super users. As a bare bones user maker this always appealed to me. Its pretty sad to have to start a review with justification for the purchase but in this case with this particular knife the justification was in the deal I finally snagged it for. The MSRP on this folder is $370. I got it for well under half price and had pretty much been wanting one to check out ever since I first saw it. There was just something about this one that stood out to me and made me want to have it.
The blade on this puppy is 5mm thick yet taken to a zero degree edge that is razor sharp. The curve of the blade is pretty nice for ripping opening packages which is something I did with it promptly this morning right after opening this one up.
The overall size is perfect IMO at 4.75" closed and 8.75" open with obviously a 4" blade. The folder is just slender enough to hide nicely in the pocket, but long enough for ample handle in the biggest of hands. It is a bit thicker than I expected at right at 9/16" but to accomadate a blade this thick I see no other way around it. The Peerless lock is impressive and strong made of grade 5 titanium in a .060 thickness. It has the proprietary bend at the contact and thumb release spot to both give more contact to the blade and strength to the lock but is more than a bit tight at this point. It sticks pretty good at this writing but if this goes like usual that will probably work in over time and use.
The pocket clip has perfect tension and is not difficult to slide over the pocket of even the thickest pants I own (my backyard outfitter cargo pants).
The texture of the lock on the release area is quite aggressive. Aggressive enough to take off skin with repeated use and yet the thumb stud has no texture at all and is smooth. In fact if there is one thing I know already that I don't like about this folder its the thumb stud. My thumb tends to miss it and I find it difficult to open for both the stud slickness and the fact that the blade sticks closed pretty tight from the detent ball on the lock. As a result it is not a folder that just opens right up without thinking about what you are doing for me which can only mean one thing. Remember I'm a backyard mechanic. It means new thumb stud ala STR.
The non sharpened serrations on the spine of the blade for added grip texture for the thumb are excellent providing perfect grip and placement for the thumb.
The fit and finish on the knife is top shelf. The mirror polished blade and attention to detail both inside and out are exactly what I was expecting.
Is it worth the MSRP? Well, no, not in my opinion anyways. But its not bad for $159.95 if you can find one for that. I've bought lesser knives for more for sure some just recently in fact. I have tried off and on to buy one of these Spectre knives for a long time and no one ever had them in stock. All I ever saw was presales or preorders and pictures until just last week. I had heard that Lynn was so picky that he kept refusing them when they'd make up new prototypes. In my opinion it falls a bit short of expectations and that is always a dissappointment. I had to know though. I do like it and I fully intend to keep it but it won't see the kind of use I had hoped unless I make some adjustments to make it suit me personally. For one I have to be able to open it easier or its just not going to see any use at all. As it is I've nearly cut my thumb twice now from it sliding off the stud on the way out.
Even with these faults as I see them I'd rate the Spectre a high 8 on a scale of 10 with 10 being the highest score and in truth I'd have to still say that for the money the Ultimate Hunter from Cold Steel is a far better value for the $ at $50 plus or minus. But I knew no one had written anything about this one and very few people I know even have one so in the end I bit the bullet and got one of my own. Here are some shots of it on my flat bed scanner, lock view, spine view, opened and a closed one for a clip side view. Its a sweet looker and very cool just not quite what I had hoped in the way of a good EDC user from a company that is usually the master at making super user knives.
STR
STR
