cold steel trail hawk question
I have sevral cold steel trail hawks....Use em for everything...I order a couple last year and they had a set screw in them...is this the new style...my older ones dont have the set screw...the reason I ask is the newer ones dont fit my kydex sheathes they have a slightly wider head...anyone know where I can get the older style?
thanks
You could try some of the online liquidators . Type in cold steel trail hawk and sale . See what comes up .If you get any hits e-mail them and ask if its the ones without the set screw .
Sunday I saw the set screw set up on the Cold Steel Trail hawk for the first time. I think if might very well, do the trick but I'm concerned that if too long a screw is used it might weaken the top of the handle and make it split on impact when throwing. Right now I'm doing some regular throwing with the old version and as always will need to replace the handles pretty soon. Hopefully my skill will improve where I'm sticking more frequently and not subjecting the hawk to as much impact damage from a bad throw.
Best
Dwight
In a way ,I really like the set screw. You may think I'm "screwy" , but let me explain.
If you want a nice tight fit for chopping you can tighten the set screw with your allen key. If you want to throw, just loosen the set screw so the handle slides back on a miss hit. I really like the versatility. JMO.....
BTW the steel on these hawks takes a blueing very nicely.:thumbup:
I've never heard anyone mention a set screw in CS hawks before. Any chance someone can post a pic? Thanks
I found the set screw useless for any purpose. Misunderstanding its purpose when I first got the trailhawk, I tightened it up and started throwing the hawk. Being a complete beginner, I mostly failed to make the hawk stick and subsequently put a nice gouge in the handle made by the set screw as the head came flying off the handle. I removed the screw. As my throwing skill improved, I found I just had to tap the handle tight every once in awhile....no biggie. As for tightening the screw to chop with, I don't think the trailhawk should be pushed much beyond splitting kindling and it's last choice if you've got better alternatives. It's real light weight tool. I gave away both the trailhawks I bought a couple months after I purchased them. They are a great introductory throwing toy. They got my son excited about the hobby. The thin blade is eay to stick. The light weight doesn't wear you out. But it is entry level quality and doesn't compare well to hand forged hawks that cost as little as $20 more. There is a world of difference. My son has already killed one of the trail hawks through no intentional abuse. The first time he hit the hammer end of one with the cutting edge of the other [while throwing] the blade bent....the beginning of the end. Two words: hand forged......an opinion...that's all.
