I'm really digging the cold steel mini tuft lite and regular tuft lite and glad they are going to bring it back in a new steel in 2020.
I love both knives and wish they came out with special edition runs with upgraded handles and steels. However there is 1 massive problem with the tuft lite vs the mini.
The mini's blade angle is WAY better. Look at the up swept angle of the blade
vs the flat angle of the tuft lite
This makes the tuft lite almost impossible to utilize the entire blade length on a flat surface such as a bench which I bet a lot of people use it for. Instead of using the whole blade length, you excessively use the tip of the blade because the handle blocks you forcing you to tilt the angle of the blade up. No such problem with the mini.
Here it is flat, and unable to use the handle as a result because the flat table blocks the handle space.
Not sure if anybody else has this issue. Also, it allows your tuft lite to stab better, you hear that Lynn?
